Does anyone know of a good/decent cigarette powered air compressor for airing back up after airing down? Currently running 35”
I use this unitGood point!
Is there one that connects directly to the battery with clips?
VIAR is a good value air compressor.I use this unit
VIAIR 400P Portable Compressor https://www.amazon.com/dp/B000X9AXR8/?tag=wranglerorg-20
I paid $125 for mine, slightly used.
VIAIR makes some very good 12v compressors. There are others, such as ARB, but the VIAIR 400 is the only one I have experience with.
The answer honesty depends on your budget and how often you will use it.Does anyone know of a good/decent cigarette powered air compressor for airing back up after airing down? Currently running 35”
Used this model all summer, worked for 33sView attachment 75646Viair 00088 88P Portable Air Compressor , work fine for me, will get a bit hot, note only run 32". Hooks to battery and with the length of hose and clip leads easy for your jeep and to help out others on the trail. Also work great for beach toys for the kids.
