Ran signal peak today solo. The trail isn't difficult but I did find a few large rocks that I managed to high center on (100% avoidable).
You'll walk right up it. The beginning half is "more difficult" and the return from the summit is a fire road. (Other than the 2 rocks I found.) It's a fun trail but only took a few hours so I wouldn't drive from Lakeport just to run it. Perhaps before or after your next rubi run.One of these days I'll get to run this trail!
Geez, you nailed that rock dude! You’d have to know that happened at the time, right?!I just noticed I already got my monies worth out of the savvy bumper hardcore upgrade.
It surely happened on the rocks I high centered on. I hit just about everything on those things. Oil pan skid, center skid, all 4 control arm mounts, and both sliders all took superficial damage. But, it was worth it.Geez, you nailed that rock dude! You’d have to know that happened at the time, right?!
So you are running the arms the rear TJ AR kit comes with or did you order different ones?I had some time over the weekend to look at the rear antirock and cycle the suspension. I am extremely grateful that @mvigo drove over Saturday morning so I could take a look at what @mrblaine did to his jeep and also lent a helping hand to figure out mine. Before he arrived I was thinking I'd need a 1/2" spacer and new wheel studs to clear.
After bending the Antirock arms a bit more so the Heim barely clears the frame while cycling and adding 1/4" worth of washers to the wheels to act as temporary spacers the link cleared the tire on full articulation.
All I can say is @mrblaine is a magician (wizard). @mvigo and I have, more or less, identical setups in terms of tire size, lift height, midarm, wheel backspacing, etc but Blaine was able to make his work with less bend on the arms and no spacers.
Once the spacers come in I'll do a final test before burning in the mounts.
I am running arms off of a JK but Blaine said that the stock TJ front arms would have been a better fit - 18". I had to cut a link off the arms I bought. I added around a .75" offset bend with a 20-ton press to clear the shock tower/frame.So you are running the arms the rear TJ AR kit comes with or did you order different ones?
Good to know, thanks homieI am running arms off of a JK but Blaine said that the stock TJ front arms would have been a better fit - 18". I had to cut a link off the arms I bought. I added around a .75" offset bend with a 20-ton press to clear the shock tower/frame.
Happy to help.Good to know, thanks homie
Yes, it was an A/C compressor but will now be used to pump air.What am I looking at? An A/C compressor?
It's coming along.More importantly, did you organize your tools?
I defiantly don't want to lose my A/C.No need for A/C in California? I can't imagine not having it here in Arizona
