If you want to put a limited slip in a Dana 35, I'd recommend the Eaton TruTrac.Looking to Install locker on my Dana 35 and 30 , running 33x12.50x15 and geared to 4.56 . Wanting to do limited slip on the rear and a small lunch box locker in the front . An recommendations ?
Yea my plan was going with the Eaton true trac limites slip for the back , just put locker on there for the front , my question I guess is would having two different sets work ? And how well for street use and off-road ?
X2 100%. If you drive it in the snow, you have to go selectable up front, leave it open in the snow and lock it out when you need it on the trail. Auto lockers in the front in the snow will drastically reduce your ability to steer.For the street I would advise against a lunchbox locker in the front as it can be extremely dangerous if you ever need 4wd in wet/snowy conditions.
what I’d I go all around limited slip front and back ? I will be using it mostly for winter and light to mid off road and that’s once every month or so . Other than that it will be driven around as a daily if it has to be . Located in Denver ColoradoFor the street I would advise against a lunchbox locker in the front as it can be extremely dangerous if you ever need 4wd in wet/snowy conditions.
Sounds like limited slips would be a good choice then. I have a Dana 30 Truetrac I’ll sell ya. I had 4.56 gears on it so you should be set.Wh
I have Eaton TruTrac's front and back. Love it.Wh
It definitely is, it was surprisingly discovered that the R&P gears run substantially cooler when lubed with a conventional than with a synthetic. The conventional has better heat extracting/sinking characteristics. Which is why mainstream companies like Revolution Gear and Currie recommend conventional gear lubes.although I'm not entirely convinced conventional oil is better than synthetic in the differentials. It is much nicer on my wallet however.
When I ran front & rear Truetracs I spoke with a Detroit (pre-Eaton) rep who said it didn't matter if it had the friction modifier or not, that the Truetrac doesn't care one way or the other since it is gear based. The other gears inside the axle don't care either.It's not easy to find convention gear oil without friction modifier already added. Often you can't tell if it does or not. Eaton recommends conventional gear oil, and oil that doesn't have friction modifier for the Truetrac. I need to locate some when I change the diff fluid after break in.
I don't really know why it would matter either. They say that, but who knows why.When I ran front & rear Truetracs I spoke with Detroit (pre-Eaton) rep who said it didn't matter if it had the friction modifier or not, that the Truetrac doesn't care one way or the other since it is gear based. The other gears inside the axle don't care either.
An Eaton Detroit Truetrac LSD in the rear axle. Avoid installing a locker into a stock Dana 35.I live in Florida where we only encounter mud, dirt, sand, and mud, did I mention mud? What would the ideal set-up be for Dana 30 and Dana 35?
