Oh and I can second how quiet the turbo diesels are.
But that's not all turbo diesels. I took a ride in a TJ with a 4BT in it, and that thing was do friggin' loud with the top and doors off that I think I got a headache!
So I was concerned about that as well, but you have to realize there is a massive difference between the hp and torque curve of our 4.0L and the Kubota V2403 and really between a gas and a diesel engine in general.
Here is the best one I could find for our 4.0l:
Now this was at the wheels so it's a little bit off, but you can clear see below 2000rpm which would be where you would "cruise", a stock 4.0L only has about 50 ~ 60hp and around 155 ~ 160 ft-lb of torque.
Now let's take a look a the Kubota Diesel:
Again this is a stock turbo V2403 which I believe is 4 PSI and I'm going to be pushing around 25 ~ 28 PSI of boost through an intercooler to this engine. First off check out that torque curve. It's in newton meters but even with the bigger turbo, the torque curve is going to basically look the same, just with significantly more torque from 1300 ~ 2800rpm. The HP is going to go through the same pattern as well, you will have more horsepower and torque at EACH RPM level with a Kubota diesel compared to a 4.0L gas engine.
Yes add a Bank's turbo kit to your 4.0L and you will have more PEAK horsepower and probably the same torque. However if you were to compare WHERE the RPMs are when you get that horsepower and torque, the Kubota diesel will have out matched the horsepower and torque at lower RPMs where you would be cruising around.
I notice this EVERYDAY I drive my 2006 Turbo Diesel Jeep Liberty. Once my Liberty hit's 5th gear (overdrive) it's not coming out unless I go below like 48mph because it's using torque to keep me moving, not horsepower (though in all reality it's a mixture of both).
My brother borrowed my Liberty and trailer to move from VA to NC, and when he got back he said it was both weird and awesome how when it hit 5th gear and turned on cruise control, even when climbing steep Virginia hills, the Liberty just stayed in 5th gear and never lost more than 1mph of speed.
I have a hill close to my house where I go up it all the time in low rpm in 5th in my Liberty no issues at all. In my Wrangler it would have to downshift into 3rd to go up the hill. In my wife's 2017 Jeep Renegade that thing has 9 gears and I swear it goes down like 4 gears to go up that hill. *Sidenote* My wife loves her Jeep Renegade and I'm delighted to have her driving a Jeep as her daily!!!!
Didn't mean for this post to be so long, but it took me owning a Turbo Diesel Jeep Liberty to realize the massive difference between Diesel and Gasoline engines. I fully expect once I have this swap done to go up that hill near my house and have it the transmission in 4th gear/overdrive with the torque convert locked and to climb the hill with no issues at all because I'll be at 55mph at around 2100rpm which will be giving me around 300ft-lbs of torque compared to my 4.0l giving me about 155ft-lbs of torque.
Thanks!!!!
Grant
I think my only issue I would face at this point is I would want to adapt it to a 4L60E GM transmission most likely (I prefer an automatic), and I'm not 100% sure they make an adapter for this.
The other issue is wiring. Does this engine have a ECU? If so, how do you get it to talk to the Jeep PCM? In addition, is it possible for it to work with the factory gauge cluster, or is that something that hasn't been figured out yet?
