Hello All,
Getting back home soon, and wanting to do a SYE to help with some driveline vibrations I've been having. Anyhow, did some research, and with the fact that I figured I might as well do some other items while I have the T-Case off, the plan snowballed into the list below:
SYE
• Teraflex Megashort SYE & Adam's DS Kit
• RTV
REAR SUSPENSION
• CE-9103SA - Savvy JJs Aluminum Adjustable Rear Upper Control Arms TJ/LJ
• CE-9106SA - Savvy JJs Aluminum Adjustable Lower Control Arms TJ/LJ
• Currie Enterprises CE-9601 Rear Lower Shock Mount Extension
CLUTCH
• LuK 05-065 Clutch Kit
• National 614093 Clutch Release Bearing Assembly?
OTHER
• Savvy Transfer Case Cable Shifter Kit for the 231
Now, have a couple of questions of about this list.
Thanks in advance!
SYE
• RTV
REAR SUSPENSION
CLUTCH
OTHER
- Firstly, is there anything I'm missing, or any other good items to include while I'm installing everything else and have the T-Case split open?
- Secondly, are there any special tools I will need to buy or rent?
- Thirdly, I'm rather torn as to whether or not I should go with the LuK kit included throw out bearing, or the national one. One one hand, the National bearing seems to be favored, as the LuK one has a composite material, but on the other hand, the national bearing doesn't have the best reviews (3.4/5 stars on Amazon), it's rather pricey (seeing as it's just $30 shy of the Clutch kit itself), and I saw a post in which Jerry described the composite material as actually being superior
Thanks in advance!
