As part of my regear I am installing an ARB Air Locker and have a question on shim stacks, any guidance much appreciated.
When I pulled my old carrier I romved the bearings and measured the shims so I had a starting point when I installed the new locker and gears. The shims in the old set up measured 58 thousandths on the ring gear side and 38 thousandths on the non ring gear side. I understand as part of the ARB set up I need to use the ARB master shims included with the lockers, however, I have just opened one of the master shims included with the locker and it measures 97 thousandths. Is the master shim in addition to the shim stacks I should use?
In addition, to the master shim I have 8 shims in the ARB pack, two x 0.031, one x 0.013, one x 0.12, two x 0.006 and two x 0.004. With these shims I can make close to the 0.058" or 0.038" shim stacks. But only if I do not count the thickness of the master shims.
