Why?I’ve never been a BFG AT fan personally. I would get anything BUT them.
You referring to imperial measurements?Not true to size, can’t clear out for shit.
Im sure all manufacturers run 0.5 smaller than what is stated.
I just put a new set on my 2500 this week, had to go a hair taller than OE due to supply chain issues impacting everything. Still made in the USA. Put on 285/65R20, took off 285/60R20 Firestone TransForce AT. A truly garbage tire.Replaced my 11 yr old BFG T/A KO with KO2s yesterday (2006 LJR, so LT 245/75-16). Got them from Discount Tire with a 10% Veteran discount. Had to wait a week for them. I got the guarantee as a 'Murphy' hedge, which works. I had the old tires forever and never had a flat. Had to get load range E, as the C is not available in my size. Run them at 29 psi (LJ with a hardtop) and they run great. If I want a soft and quiet ride, I take the Grand Cherokee. This is a Wrangler (i.e. JEEP, but it rides so much better than my old CJ-7! Smart guy said once, "Everything is relative."
Drive them mostly in the sand on Padre Island and some light off-road in the dirt; no rocks. Don't even air them down. Good tire.
I ran them in 33" on my TJR. Pretty impressive off road for an AT tire. I miss the TJ, its was too pretty to beat the piss out of like I wanted to.KO2's is what I went with for our mostly street-driven Jeep. Low road noise, aggresive enough tread for the occassional off-road run, and AVAILABLE.
Is that a fact?Some might, others don’t. In my experience BFG are significantly overstated on their “size.” Your mileage may vary.
I would not categorize this as a "mistake" ... Imperial tire dimensions are "nominal", not precise."Thus i am asking you, because i have not look at all brands. I am also very familiar with how far Americans willing to bullshit just to not admit their mistake."
FWIW I measured my 33x10.50 ko2’s when they were new and it was exactly 32.5 inches unmounted. Mounted they measure like 31.something. People get all worked up when their mounted tire doesn’t measure true to size and I have never been able to wrap my head around that. I have not seen any real evidence that bfg’s run smaller than their stated size.Some might, others don’t. In my experience BFG are significantly overstated on their “size.” Your mileage may vary.
I have about 25k miles on my KO2's. They are at 9/32 tread depth. I can't balance out a shimmy on 2 of them, so they stay in the rear. 33x10.50x15, btw.
I use a product called "Ride-On" in my Harley; haven't thought about using it on the car or Jeep, but it might be helpful for balance issues on large tires, as well as providing some leak protection.I'm anticipating balance issues, since I've had that problem on 30's and I hear it gets worse the bigger you go. Planning on a set of Centramatic dynamic balancers to go with the new tires.
Buy some beads, they work if you use the prescribed amount. Centramatic is good too, just spendy for essentially the same thing.I'm anticipating balance issues, since I've had that problem on 30's and I hear it gets worse the bigger you go. Planning on a set of Centramatic dynamic balancers to go with the new tires.
