Arizona Rock Crawler
Got my savvy bumper corners on today. Grind the corner of the bumper down a little bit and you can get them to sit right.
My passenger side fit pretty nice.
My driver side bumper had a pretty good sized dent in it which made lining up the corner much more difficult. A little help from the impact wrench got it acceptable but not perfect. This bumper was designed to be run with these corner guards on so don’t skip on them if you buy the savvy bumper and wheel in big rocks.
One of my questions.
if this is the greatest bumper since sliced bread, why do we need a reinforcement? Why not a steel bumper and call it done? The weight would be slightly more, but hey, my Warn Stubby is 39 lbs. that ain’t much more, and I don’t need to reinforce. Shouldn’t it be acceptable to buy a 39lb bumper?
The welds at the corners can crack due to heavy impact.
Why not?
From what I've seen the shipping weight for the Warn stubby is 71 lbs.
It isn't?
Reactions: Tob and Vasq
There’s a few nice design things to appreciate about the Savvy bumper that almost no others I’ve seen do. Deeper top deck, lower wraparound, ...
If you recall, my Motobilt stubby is heavily modified to be a Savvy bumper in most ways short of being aluminum. And it ended up being about 35lbs before the lights. For the amount of work to get there, the Savvy starts to look like a good deal.
Reactions: Tob
Science, that's why. The corners should not be optional. The corner is welded to produce the shape. When you weld tempered aluminum, it causes the material to transform back to the un-tempered state and is a fair bit softer and by virtue of that softness more susceptible to damage.
It is not an issue of material selection either. It is an issue of location on the vehicle and where you intend to play and how hard. Steel in weights light enough to be tolerable or 1/4" and 3/16" in similar designs suffer the same fate.
You can see one of the problems I solved where similar design bumpers get bent upwards at the lower edge. The corners get tweaked upward which the corners really help to mitigate on the Savvy bumper.
It even happens to rear steel bumpers.
If you are going to play in the rocks, the penalty for doing so requires creative solutions, not lots of weight thrown at the problem.
That and who the hell ever said that they are the greatest bumper ever?
I’m aware of the need for the reinforcement due to the welding making the Al soft. What I didn’t understand was if that’s the case, why was it designed that way to begin with? Your material selection section and playing in the rocks remark answered my question. 👍🏼
“Greatest since sliced bread.” 😉 @jjvw and @rasband made a few design statements above that imply in that direction.
They didn't design the bumper, I did and I won't and would never refer to it that way. It is a great solution to a very common problem. If you don't have the problem, then you likely don't need the solution.
It was designed that way because you can't create that ramped profile easily any other way. Again, those corners should not be optional.
Our comments were after you made the assertion, no one ever said that statement. Somethings are just the best for now, someone else (or even Blaine) could design a different one that’s better and at that point people will share why it’s the relative best for them.
Reactions: jjvw
I know, but these comments by various people are strewn around this forum in various threads. It doesn’t really matter, you did think it was a better design for what you needed. So did Josh. Who really cares? Doesn’t seem really relevant. The main question I had was why design a bumper that needs a reinforcement at that location if a steel bumper would not need reinforcement. Blaine explained why it was not just material specific. We got some good tech out of it, which is why I asked. Now are people going to attack wanting knowledge?
We (plural of majesty) should also point out, that I never said it was the greatest bumper. We said “if this is the greatest bumper since sliced bread...” This functions as a 3rd class condition (some call these 1st), meaning 50:50, maybe it is, maybe it isn’t. It would be a 1st class condition (some call this 0) if there were certitude. There can be some inexactitudes in the English language at points that other languages don’t share, but the point remains that some people just have to twist things because they are going to attack you no matter what you say, even if (another 3rd class condition) you say the same thing they say, which I have examples of on this forum.
@jjvw and @rasband
@jjvw and @rasband
Or, you could have just asked why do the corners of that particular aluminum bumper need reinforcement when it looks like very few steel bumpers of similar design don't? Takes all the bullshit right out of it and we still get to learn something.
Reactions: rasband
Next time I’ll send my question to you privately so you can re-word it before I post.
I honestly don’t know where the bullshit is in my post. I just wanted to understand. Here it is so you can show me.
“One of my questions.
if this is the greatest bumper since sliced bread, why do we need a reinforcement? Why not a steel bumper and call it done? The weight would be slightly more, but hey, my Warn Stubby is 39 lbs. that ain’t much more, and I don’t need to reinforce. Shouldn’t it be acceptable to buy a 39lb bumper?”
If you ask questions like you have your head up your ass, does that change the value of the question or just the context it is being posed from?
Do you really not see the difference in how a question is posed?
Of course, but I wasn’t trying to be an asshole at all. And I don’t think of various ways to ask a question. I was in a stream of thought in Garrett’s thread and just posted what I was thinking. If it was offensive, I’m sorry about that, because I didn’t intend to be offensive.
EDIT: the way you phrased your question is condescending. It centers on the word “really.”
@jjvw and @rasband
