If it's not leaking then replacing the radiator doesn't always help the temps. You might research that a bit. If you can't find Mopar any stock style will be fine with the plastic tanks and aluminum core. Just don't go all aluminum or brass multi-core. The Mopar doesn't cool better (than other factory style replacements), it just lasts longer.
I have a used one from a manual if you’re interested. Has 58k on it and doesn’t leak. I swapped to an auto, so I needed a radiator with the auto cooler.
I have been waiting for a Mopar Radiator for two months, so frustrated. Its still drivable and stays at 200 degrees, but I stay close to home. Has any one found a direct fit OE style that they have had luck with? My next call is perhaps 1 800 Radiator I have one in my area.
I've never thought of a sample size of one being valid. Who knows what you might have missed, chemical flush, radiator had a manufacturing defect? It's possible if you ran your Mopar radiator in Death Valley conditions you'd overheat and wonder what you missed, maybe not?I compared an aftermarket to Mopar side by side in 2018 and found that statement to be false. The aftermarket radiator had about 30% less surface in both fin and tube, making it impossible to have the same heat transfer capability. The findings aligned with the fact that my TJ regularly reached 235 with the aftermarket radiator and I never saw past 208 again with the Mopar. And before you ask, no there were not confounding variables present because I replaced the entire cooling system one piece at a time in my stubbornness thinking there was no way my fairly new aftermarket radiator was the source of my heat problem.
Looks like Fiat is moving away from the current Mopar manufacturer to magneti marelli for our radiators. Wonder what that means for quality and longevity?
I would expect at least that the tube count and fin density would remain the same or equivalent. Who knows about longevity.
Local dealer says they are discontinued. Good bye mopar radiator?
