Can anyone who has ever done the ball joints on a TJ before confirm whether there adapters are actually needed or not?
http://www.amazon.com/dp/B0002SRGW0/?tag=wranglerorg-20
Yes they are but you don't need to buy them. I borrowed the 27165 Dana 44 adapter kit from AutoZone which works perfectly for the TJ's Dana 30 and Dana 44.
If they don't have the Dana 44 adapter kit, their 27089 tool kit has the press and Dana 44 adapters.
No, the standard ball joint kit doesn't include the Dana 44 adapter kit. You have to get it separately or get the non-standard 27089 ball joint kit which does.Glad you told me this. I didn't know AutoZone had the Dana 44 adapter kit. I assume it comes with their typical ball joint kit they loan out?
Have the kit numbers I gave above handy and call around to the various AutoZone stores in your area to see if they have them. My local store didn't carry the 27165 adapter kit but another one 5 miles away did Chris. I only needed the adapter kit since I already had a ball joint kit.
My HFT ball joint kit didn't quite completely survive removing/installing my last set of ball joints. I finished the job with it but I ended up deep-sixing it afterward, it was bent up enough that I wouldn't have trusted it for another job.I borrowed mine from what was then Checkers, now O'Rileys. Just told them what I was doing and they gave me what I needed.
An alternative is the kit from Harbor Freight. I have replaced several sets of ball joints on a couple of jeeps(my YJ and TJ). Work well for u-joints also.
Get the 4x4 kit and everything is included.Yeah, I will probably buy the HF one. I'm assuming that the HF one doesn't come with the correct adapters though?
That's what I have
That may not be the same HFT ball joint kit I had but it sure looks just like it and the adapters in mine didn't do the job. That's why I had to borrow the Dana 44 adapter kit from AutoZone. I recall that the adapters in the HFT kit were flat on both ends and the TJ's Dana 30/Dana 44 front axle requires an angle at one end to work which the Dana 44 adapter kit from AutoZone has.
