I have oil seepage from my headgasket on my 2004 4.0. I figure if I'm already going to be down to the heads for a gasket replacement I might as well replace it with an aftermarket performance head and valvetrain. And on top of that should I spend the extra and go with aluminum heads or go with the cast iron. Not planning on doing anything to the bottom end, so the block and everything below that should be stock, but I'm thinking of sticking with a cast iron head selection as to conform to the blocks heating/cooling expansion/contractions for long term usage. Any recommendations?
