I have an automatic so I'm not up to speed on all these new driving techniques. I use engine braking, are people using clutch braking now?
Sarcastic humor at the notion that it is better to downshift and wear out a much more expensive to replace set of components rather than use the service brakes that are comparatively cheap and easy to replace.I have an automatic so I'm not up to speed on all these new driving techniques. I use engine braking, are people using clutch braking now?
Are you the thread police or do you have his answer?Huh, OP never got his answer
A properly done downshift doesn't wear anything. I guess it's technically wearing the throwout bearing when the pedal is down for a second or two but the idea is not to slip the clutch at all. Most clutches on TJs last what, at least 150K? What's the cost difference between brakes and clutch over that time? How much is due to "downshift" wear and not starts and wheeling when you actually do slip the clutch on purpose, who knows? Not downshifting because you are afraid you are going to wear out the clutch is not something I'd do but if you've done the mental math and that's your thing then go for it. It's funny enough to me that I'll make fun of it. Hey, I bought a manual but don't wanna wear out the clutch cause it too expensive.Sarcastic humor at the notion that it is better to downshift and wear out a much more expensive to replace set of components rather than use the service brakes that are comparatively cheap and easy to replace.
If there is anyone who can intentionally miss any valid point made, it is you.A properly done downshift doesn't wear anything. I guess it's technically wearing the throwout bearing when the pedal is down for a second or two but the idea is not to slip the clutch at all. Most clutches on TJs last what, at least 150K? What's the cost difference between brakes and clutch over that time? How much is due to "downshift" wear and not starts and wheeling when you actually do slip the clutch on purpose, who knows? Not downshifting because you are afraid you are going to wear out the clutch is not something I'd do but if you've done the mental math and that's your thing then go for it. It's funny enough to me that I'll make fun of it. Hey, I bought a manual but don't wanna wear out the clutch cause it too expensive.
I know I knowYep, far easier than pulling a tire and rim off of both sides.
Pretty much anything held against a high speed spinning iron disc is going to make dust. If the iron doesn't wear it away, it will wear the iron away. The only difference between a "low or no dust" pad and normal is simply the color of the dust. Lighter colors show up less giving the impression of lower dust.Yes. Dusty and they stop well. If dust is your concern, ceramics are good. If your brakes actually stopping well is the main concern, black magics.
So it is your experienced opinion that I can tell all my clients they can easily expect 180K out of their clutches?My dad also taught me to downshift going into stops. He never rev matched, just down a gear and clutch out. 189k miles out of the original clutch and it wasn’t even shot when it got pulled (was doing transmission work so it got swapped). Downshifted into every single stop. There are valid arguments for not downshifting, clutch wear is not one.
I’ve found problems with keeping my black magic pads in good working condition around the city even without downshifting. If you are not in a city, they might be easier to keep in shape. They certainly are not the best pads for every driving style. But when you need to stop, they stop well.
You make a valid point about clutch wear and replacement cost, we just weigh the cost differently, some people probably don't consider it at all. I've been on both sides of this at points in my life. I think driving a manual and downshifting, double clutch, heel toe and all that is rewarding enough to justify the potential extra cost.If there is anyone who can intentionally miss any valid point made, it is you.
I wouldn’t tell your clients anything about clutch life. Too many variables. Anybody can smoke a clutch in 1000 miles if they are trying to. My point was just that plenty of people can get 200k out of a TJ clutch, with downshifting or without.
This would be a good poll for the forum, I’d be curious if a larger sample size. I’d be pretty happy with anything over 120k as an arbitrary number.
I’ve never noticed anything abnormal dust wise from mineThose of us who wash our jeeps occasionally never see BMB dust.
