No vibration problems with the lift and tires?
I haven't had any vibrations at all.
Did you regear your Jeep because you ended up going with 33's or did you end up needing to do it anyway for the 32's?Mine's lifted around 2" suspension and 1" BL and I'm running 32s. I should have gone with 33s but I wanted to avoid regearing. It's currently at the shop being regeared now
31’sI am 16, yesterday I just finally saved enough to get a TJ and bought a 97 TJ Sport, and I have a few months before I can actually get my license so in that time I wanna make it look great, one of the first things I was gonna do is replace the old rusty suspension with a some new ones and a 2in lift, then next would be rims and tires, what would be the best sizes I should use for a 2in lift.
Definitely a great start to a great addiction. As mentioned make it safe and steady. 31" will be right for a 2" lift and will look great as well. Make sure the brakes are up for good use and get the alignment done by a good reputable shop after the lift is installed.I am 16, yesterday I just finally saved enough to get a TJ and bought a 97 TJ Sport, and I have a few months before I can actually get my license so in that time I wanna make it look great, one of the first things I was gonna do is replace the old rusty suspension with a some new ones and a 2in lift, then next would be rims and tires, what would be the best sizes I should use for a 2in lift.
No, I'm still on 32s with 4.88 gears. Pretty happy with that choice.Did you regear your Jeep because you ended up going with 33's or did you end up needing to do it anyway for the 32's?
I like the look of your 32's on a 2" lift kit. Also the raptor paint looks great
