Starrs
TJ Guru
Reserve your decision
looking for the right Gstring LOLI’ve been patiently waiting to see. What are you holding out for?
That would be a nice touch. Might even salvage it with a hood bra up frontlooking for the right Gstring LOL
Look at your body mounts. Stock is about an inch thick disc of rubber. A body lift usually consists of a spacer stacked on top of the factory mount.Is this the crack u guys r referring to?
Does this mean I have a BL?View attachment 34354
Appears to be a 0.5” crackIs this the crack u guys r referring to?
Thank you. I bought it like this. I don't know what I have... :-/Appears to be a 0.5” crack
I think I've seen just that when crawling around under the jeep. I'll look again closer tomorrowLook at your body mounts. Stock is about an inch thick disc of rubber. A body lift usually consists of a spacer stacked on top of the factory mount.
Sent from my SM-G950U using Tapatalk
I'll take some measurements from mine when I can. It looks like the largest I could do with the manual bender would be 48". The largest lower tool we have for the hydraulic press brake is 44.500" inches. Unfortunately, the upper tool was cut down years ago into smaller pieces and resized for different angles. Doesn't mean I couldn't come up with something, though. I have access to different grades and thicknesses of aluminum, as well. I might just experiment a bit, and see what's doable, and what isn't...View attachment 34353 I feel like I have uploaded this image atleast 5x lol. I still to this day think the OME 2.5” lift with the HD springs will fit 33” KM2s easy. BL is not needed. I can’t prove it obviously, but there is a lot of room to flex in my fender well. Anyway enjoy the all you can eat ass buffet lol
Kind of the norm I guess with these TJs not sure. Seems like a lot of ppl recommend BLs. I know Dirk at DPG reccomdends then, but I’m not a fan. I’ll prolly take mine off eventually if I feel like it.Oh god... I hadn't actually seen the rear view before with a body lift... It truly is hideous!
I know that bolt! Funny I never see that bolt come up when I assume everyone has trouble with it. I didn’t even bother, knowing I’d get the BL soon to match my MML. It’s back on now, of course.Patience young Jedi's. Still need to black out the crack and figure out how to drill a new hole for the driver side lower mount for the fan shroud. Held on by 3 bolts right now, so not complete. I hate to post pics when shit's not complete.
Several really good modifications require a small body lift unless you are ok chopping up the body. Raising the transfer case and gas tank skids are the most common and most important. The Savvy mid arm also requires it.Kind of the norm I guess with these TJs not sure. Seems like a lot of ppl recommend BLs. I know Dirk at DPG reccomdends then, but I’m not a fan. I’ll prolly take mine off eventually if I feel like it.
Oh my gosh you guys are OCD. There are so many advantages to a small BL, the function far outweighs the apparent form defect; allowance for bigger tires, less bump stop, more articulation, more room for oversized spare, easier access to fuel filler, more tuck capability, shall I go on? 99.9% of people will never notice. You can paint it, buy a bumper to hide it, remove rear fender covers and paint it all one color and it will all but disappear. I don’t regret mine at all, and that’s why guys like Blaine and Dirk recommend them.Kind of the norm I guess with these TJs not sure. Seems like a lot of ppl recommend BLs. I know Dirk at DPG reccomdends then, but I’m not a fan. I’ll prolly take mine off eventually if I feel like it.
I agreeOh my gosh you guys are OCD. There are so many advantages to a small BL, the function far outweighs the apparent form defect; allowance for bigger tires, less bump stop, more articulation, more room for oversized spare, easier access to fuel filler, more tuck capability, shall I go on? 99.9% of people will never notice. You can paint it, buy a bumper to hide it, remove rear fender covers and paint it all one color and it will all but disappear. I don’t regret mine at all, and that’s why guys like Blaine and Dirk recommend them.
I don't think this picture is loading right but if so, check this out... pretty bad lolOh god... I hadn't actually seen the rear view before with a body lift... It truly is hideous!
I don't think this picture is loading right but if so, check this out... pretty bad lolView attachment 34378
