Oops, anti-seize. But if corrosion is not an issue, I probably wouldn’t worry about itwould use which, the Threadlock? I live in GA so corrosion is very much not an issue
Corrosion isn't much of an issue in Colorado either but I recall 2-3 of the factory bolts being really tough to get out. There was moisture inside the tub. I would still strongly recommend antiseize on the new hardware.would use which, the Threadlock? I live in GA so corrosion is very much not an issue
... I'm not a huge fan of the crack between the body and rear bumper tho..... not the end of the world, but does anyone know of any type of rear armor I can get to cover it up?
Like I anticipated, got antsy and put the bl on last weekend. Love the result tho! I'm not a huge fan of the crack between the body and rear bumper tho..... not the end of the world, but does anyone know of any type of rear armor I can get to cover it up?
if not, I'll just deal with it. it's not THAT bad.
I'm thinking of maybe using some 3m to attach a piece of diamond plating from the edge right below the tailgate opening and the top of the bumper.... not sure how feasible that is but I don't want to drill anything if I don't have to & don't want to spend a ton of money on it bc it just isn't on the top of my list right now... thoughts?@bobthetj03 is having this issue as well, and he only has a 1/2" body lift. I'm putting on the same body lift as well, but also dreading the "crack". Ugh...
I don’t know if you’ve replaced your rear bumper with an aftermarket yet, but they do make some that cover the crack. It’s an option for the future if you can wait to spend money to fix itI'm thinking of maybe using some 3m to attach a piece of diamond plating from the edge right below the tailgate opening and the top of the bumper.... not sure how feasible that is but I don't want to drill anything if I don't have to & don't want to spend a ton of money on it bc it just isn't on the top of my list right now... thoughts?
You can also paint the crack black. It will blend in with your bumper more and be less noticeable.
This is my next task. There will also be a gap in the rear wheel well between the frame and the splash shield. I'm glad I only did the .5" BL cause any more gap would have driven me nuts.
I can definitely take a few tomorrow.Can someone get some close-up pics of the dreaded "crack", please? Being that I haven't looked at what's involved with it before, I'm curious to know if a simple panel were to be made to fill in the gap, what would be the best way to mount it? Could it simply be screwed/bolted to the underside of the panel below the tailgate? I need to look into this on my own rig at home, but if anyone has a pic or ideas, lay it on me. I may or may not have access to a large press brake within my department that I may or may not be able to use to make what amounts to a filler panel. If I did have such access, I may or may not be able to calm the natives who are so upset with a little cleavage at the back of their rigs... Seriously, though, there is a possibility that I could come up with something. I'll look into it on my end, but how about some close-ups of anything that might be in the way. Is it just a wide-open gap that runs from side-to-side?
Both areas I have painted. I obviously hate the dreaded BL and I wish I hadn’t done it, but live and learn.This is my next task. There will also be a gap in the rear wheel well between the frame and the splash shield. I'm glad I only did the .5" BL cause any more gap would have driven me nuts.
like @JMT said, I can also get some pictures tomorrow. interested in what you may or may not be able to put togetherCan someone get some close-up pics of the dreaded "crack", please? Being that I haven't looked at what's involved with it before, I'm curious to know if a simple panel were to be made to fill in the gap, what would be the best way to mount it? Could it simply be screwed/bolted to the underside of the panel below the tailgate? I need to look into this on my own rig at home, but if anyone has a pic or ideas, lay it on me. I may or may not have access to a large press brake within my department that I may or may not be able to use to make what amounts to a filler panel. If I did have such access, I may or may not be able to calm the natives who are so upset with a little cleavage at the back of their rigs... Seriously, though, there is a possibility that I could come up with something. I'll look into it on my end, but how about some close-ups of anything that might be in the way. Is it just a wide-open gap that runs from side-to-side?
You guys are making me want to forgo my body lift altogether!
I’ve been patiently waiting to see. What are you holding out for?Reserve your decision until you see mine. It's not as bad as I portray it to be. Just different than I'm used to seeing since owning my rig.
