I'm not home to take a closer look at the Jeep but I was looking through pictures I have and realized the body mounts don't look right. Does anyone else see something wrong?
are the rocker guards cut around the upper portion maybe?
order a new set
The way that rocker guard was broke, check to see if the upper part of the mount isn’t on top of the rocker guard.
The upper body mount is on top of that rocker guard. Here’s the installation instructions. There is a slot wider than the bolt diameter but smaller than the outside diameter of the rubber mount.
Better yet, what the fuck was Poison Spyder thinking with that shit design? What they and everyone misses about that crap is you can't even out the pressure on the tub because some of the mounts sit against flat surfaces on the torque box and some sit in dimples for the top of the body mount.That's probably it. I completely missed that that's with the Poison Spyder rock rails on. I probably would have figured that out next weekend when I finally get home again and looked at it in person but you saved me trying to figure out WTF the previous owner was thinking!
Doesn't matter much. The whole design is fucked so some more fucked isn't going to change much.Won't that mess up the Savvy body lift though? IIRC the Savvy pucks are machined to cup the stock rubber pucks.
@mrblaine ?
That’s how mine are. You cut a little slice out of the height of certain mounts. You have the new style.Glad you found that as the one I found must have been for an older design and showed this:
