Hello everyone. I need help. I have a 1999 TJ and I am doing the brakes When I replaced the rear drum brakes I have 2 issues. Not sure if they are related. When I put the brakes back together the cable that run to the self adjuster appears to be to long. It will not hold the adjuster with tension against the star wheel. It appears to be to long and I threw the old ones away so I can not compare them. I have it installed correctly I think. Can I shorten the cable?? Is this possible?
The second problem is more serious. It appears that the drivers side brake is not fully releasing. I replaced the cylinder and I am having the same issue. It pops and releases. I don't think it is stuck out all the time as I would feel it. I have did research on the net and found that maybe the rubber hose section that runs to the block might be old and not allowing the pressure to release.
I am a novice mechanic and only know so much. Any info would be a big help. Thanks
