Hi all. Starting a build thread for my 2006 LJ Sport. I purchased this LJ in August 2022 after returning to home from a 4,000 mile road trip in my 2018 JL 2 door with my wife. We had a great time and wheeled in the Badlands, Black Hills, Ouray, Sedona, Prescott and Moab over a month of traveling. However, the highway miles were not kind to our bodies and the 2 door was full up with our stuff, leaving her to remark “that was an amazing trip, but I’ll never do it again!”. Outside of that trip I’ve driven my JL to Moab twice more by myself, also leaving me looking for a better solution to combine travel and wheeling. On the one hand I want to build my Jeep but on the other hand I drive it to work and so the mods don’t help the ride 99% of the time.
I decided to get a separate trail rig and trailer it out west for the future trips so I could wheel the harder trails I wanted and not be subjected to such rough highway miles. Being in Minnesota I did not want a local machine, but tried anyway and got lucky to find this 06 at a local dealer that specializes in used vehicles bought at auction in other states. This one spent its entire life in Texas per the CarFax and from my inspection it had no signs that it was every on rocks or in any salty environments. It has just about 100k miles on it and a few light mods that I could undo easily (basically just a stereo and 2” rough country lift on 33’s). It had some really bad death wobble on first test drive but the dealer got it sorted and I did not care too much about that as I just wanted a clear tub, frame and drivetrain to start with.
Why an LJ after having a JK and JL? My JK was 4 door and the wheelbase was too long in many situations, even on 35s. My JL is much more maneuverable, but also a bit short and too modern and new to really dig into with mods. I’ve had my eye on the LJ wheelbase for a while and also like the more simple systems of a 2006 which will hopefully be more conducive to mods and troubleshooting.
Here she is on the rack at the dealer, a pretty clean slate in my opinion with only minor surface rust on the frame and no spray paint that I could find:
I even looked inside the frame with a remote camera, no surprises. I looked at another LJ that had the frame spray painted and when I put my finder in the frame and scraped the bottom it came out as orange as a cheese puff!
Here she is on my rack as soon as I got home from dealer, ready to pull it apart:
The build plan:
Installed so far:
The build plan:
Installed so far:
- 4” Rock Jock short arm lift with Rancho RS9000 shocks
- Savvy tummy tuck – partially installed with some customization
- Currie CurrectLync steering
- 35x12.50x15 BFG KM3's on Pro comp series 69 15x8 wheels, 3.75” backspacing
- Currie HP44 front axle, Currie HP60 rear axle with Explorer brakes, stock widths
- 5.13 gears, Eaton E-Lockers
- Advance Adapters Rubicrawler reduction gearbox for a double low
- Slip yoke eliminator
- NP231 TC upgrades, 6 spider gears & 1.25” chain
- Genright gas tank
- Tom Woods driveshafts
- B&M shifter
- BMB 15” front big brake kit
- Anti-rock swaybars front and rear
- MORE 1” MML
- Genright lifted motor mount brackets
- Rear brake hardlines
- LOD destroyer shorty front bumper
- Superwinch SX 1000SR winch – mounted, not yet wired
- Genright roll cage
- Genright corner armor
- Genright mini boat side sliders
- MCE 4.5” fender flares
- Turn/side marker LEDs
- Auxbeam switch pod
- Subwoofer for console
- 5 channel amp
- Kenwood double din head unit with front and rear cameras
- Barnes 4WD stubby rear bumper
- PRP Summit Elite seats, 5.2 harnesses and mounts
- MORE engine skid
- Bed Tread carpet replacement kit, front & rear
- Midland MXT275 GMRS radio with ghost antenna and cool tech mount.
- Speakers for dash and pod mounted for roll cage
- Half doors, hinges and mirrors
- 13” LED bar for front bull bar - not sure I will use
- LED pods for A-pillar
- Reverse LED pods to mount in bumper - not sure I will use
- Rock lights
- AGM battery
- ECU Tuner for wheel size and gearing?
- Solve for exhaust system after cutting mine out, which turns out was a mistake as it could otherwise have been saved.
- Paint half doors, replace seals and re-key
- Power adder? Let’s see if I need it.
- Transmission flush - done
- Cooling system flush - done
- Power steering fluid flush - done
- Add filter for fresh cabin air
- Replace serpentine belt
- Check if OPDA has been replaced - done and replaced
