How much bump stop misalignment is too much? I am showing about 1” offset. I think its mostly the necessary pinion adjustment for a double cardan drive shaft is whats doing it. Ill add the plans to move the perch later but I cannot do it right now. Would this be okay even playing in the dunes for a weekend where I will likely be hitting them? For what it’s worth, they are at least set up correctly to prevent shock bottoming out.
