So on arriving the so called OEM replacement bracket for the upper drivers side rear control arm/ trac bar bracket, isn’t exactly the same, it’s definitely thicker gage steel (which is a good thing) but it’s caused the trac bar extension bracket to sit differently. It’s about 1/4 “ offset and 1/4 to high, with Some drilling and welding I could get the thing mounted but it would (If I’m thinking right) make the trac bar need to be at least 1/4 longer?
so im thinking my options are 1) buy a adjustable trac bar, which brings up the ? Do I even need the trac bar extension bracket if I have an adjustable trac bar, in other words can an adjustable track bar sit in the original OEM bracket with a 3” lift?
or 2) buy another after market bracket to weld in place of the original??
Any help thoughts or ideas would be appreciated..
