Where is this "Rock Slider Guide" of which you speak? Time to shitcan the PS. Wide open to experienced suggestions.Yikes. I wish I’d come across the rock slider guide before snagging these.
I 2nd that emotion. And I thought PS was a badge..Well shit!
Yup, I'm in the middle of the long thread on the topic and off to see if both are still available. And crawl under the PS to see exactly how they're mounted (c.2016 I think). I don't expect a lot of rocks but if/when I wanna relax...The only two standout sliders I am aware of are Savvy and the Genright Mini boatside. Anything else is about the same as long as it doesn't use the body mounts (like PS) or attach the frame to the tub (like earlier PS).
Both are definitely still available.Yup, I'm in the middle of the long thread on the topic and off to see if both are still available. And crawl under the PS to see exactly how they're mounted (c.2016 I think). I don't expect a lot of rocks but if/when I wanna relax...
Bad news, the PS need to be replaced. Good news, they weren't my mistake.Both are definitely still available.
The problem with body mount mounted sliders isn't just about rock crawling. It's about understanding the way bolted connections work and whether or not you think the body should be properly attached to the frame. PS sliders are bad engineering the similar to the way the JKS body lift is bad engineering.
I'm on the wait list. Asking quantity so I entered 1, assuming it's for the pair at $600+. Good to see the backing plates are included.Both are definitely still available.
Savvy is the absolute best set of sliders available. Genright Miniboats are very good with it's intentions, but is compromised with the steps and with the inadequate backing plates.Bad news, the PS need to be replaced. Good news, they weren't my mistake.
Yeah, I'm going to have to look more closely at both. I like having a step tho' - my wife is 5'-nothing, and I'm frickin' old. Helps that I dropped 2" tho.Savvy is the absolute best set of sliders available. Genright Miniboats are very good with it's intentions, but is compromised with the steps and with the inadequate backing plates.
If the two were combined, we would have something very special.
..or it's because the GenRight are welded on steps and the Savvy are 'replaceable'. Nice touch.The steps compromise because of the added leverage when on an obstacle?
The Savvy sliders do not have steps. Those are a smallish rub rail to help protect the body and the factory flares a bit.Yeah, I'm going to have to look more closely at both. I like having a step tho' - my wife is 5'-nothing, and I'm frickin' old. Helps that I dropped 2" tho.
The steps compromise because of the added leverage when on an obstacle? Why the hell would they skimp on backing plates.. rhetorical.
The Savvy step doesn't look much like a step but it's something anyway. Some anti-skid pads might help. Kinda-sorta like the bare look on the website, aluminum?
Rhetorical but the actual understanding of what you are doing when you design a product is not that common. There is a whole bunch of "I saw this on a rig" so we'll make one too. Monkey see, monkey do is a very poor design practice.Why the hell would they skimp on backing plates.. rhetorical.
I wish more folk would pay attention to how they use the step. I find it odd that one lifts their foot higher to hoist themselves up on the side of their rig and then step DOWN into it, very odd. If a step is going to be actually useful, it needs to be lower than the floorboard you are stepping on when you get in.I like having a step tho' - my wife is 5'-nothing, and I'm frickin' old.
Steps on tub mounted sliders are dumb because they are too high and not wide enough to be useful as steps. Then you are left with a bulky thing that only gets in the way of climbing into the Jeep and also gets in the way of rocks and trees.
The miniboats are a more aggressive rock rock crawling slider partially crippled by the dumb step that doesn't work as a step.
The Savvy steel skins are "replaceable" in the event that your wear them out on the rocks. More importantly, the hybrid aluminum/steel structure creates strength while a reducing a small amount of weight...or it's because the GenRight are welded on steps and the Savvy are 'replaceable'. Nice touch.
I have arbs,was looking at the guide (The only weakness is they are not WW2WW.)I love them,but anyone no what this means?Savvy is the absolute best set of sliders available. Genright Miniboats are very good with it's intentions, but is compromised with the steps and with the inadequate backing plates.
Wheel well to wheel well. Full coverage along the body from wheel opening to wheel opening.I have arbs,was looking at the guide (The only weakness is they are not WW2WW.)I love them,but anyone no what this means?
Oh ok,they are super heavy dutyWheel well to wheel well. Full coverage along the body from wheel opening to wheel opening.
they are super tough,and cover under the tub a good amountWheel well to wheel well. Full coverage along the body from wheel opening to wheel opening.
