First issue I've had smogging a vehicle.
I took it in to be smogged a few months ago and the only issue I had was it failing because I had just replaced the battery, so i was going to have to bring it back. When I came back a month later it would not pass because the "cat" was not ready. I figured the huge leak in the exhaust manifold could be the issue. So I replaced the manifold...sounds a lot better. (side note...shop around, I was shocked at the number of mechanics wanting over $850 to change it.)
Took it in today, same issue, cat not ready. No check engine light. I am debating just changing the cat or replacing the whole exhaust system as its 21 years old.
Thoughts?
I was also thinking about just changing the o2 sensors and seeing if it would pass...but like I said, no check engine light.
Thoughts?
