The cable is used to adjust length between the two shift levers.I made it shorter, what I need to know is what part of the whole shebang is used to adjust length?
That isn't adjusting the cable, it is adjusting the cable housing. The cable length is adjusted with it in the same mode at both levers. The cable housing is adjusted for throw or how far the levers get moved.View attachment 316963
The threaded sections and nuts allows the cable to be adjusted against the fixed position of the brackets. Look at the lever on the transfer case, figure out which way it needs to move to engage 4-low more fully, and adjust the cable position against the bracket position as necessary.
Thank ya Tober.View attachment 316963
Do I need to tell you which direction to turn the tap?So I messed up pretty bad, I was putting the TC shifter in and I dropped a nut between the transmission mount and the transmission, so I had to take the transmission mount off the transmission so I could get the nut, while doing so I stripped 2 of the holes for the tranny mount bolts, so now I gotta tap new holes into the tranny, uhhhhhhhhhhhh
what's a tap? I was talking about taping a bolt into the old holes with a hammer to force the threadsDo I need to tell you which direction to turn the tap?
I'd think most folks were kidding if they said that.what's a tap? I was talking about taping a bolt into the old holes with a hammer to force the threads![]()
Need more stickers...To delete or not to delete.... View attachment 321101
What would I do with my 3rd brake light if I did delete?
And what's a good tire plug kit to replace it with?
At least I've got a Savvy stickerNeed more stickers...
What! How?At least I've got a Savvy sticker
And a hello kitty sticker.... if ya know, ya know
I get that, and thats what is making me question removing it, but when ever I hit any sort of bump my entire tailgate rattles, its slowly getting harder to close as well.Not. For a regularly driven vehicle, I think it's foolish to not have a serviceable spare tire (and know how to change it). It's one of those things that's better to have and not need, than to need and not have.
I'll trade you a tom woods one
I'm good on stickers....I'll trade you a tom woods one
