Thanks. What is the DEI kit? Sorry if it's mentioned earlier in this thread; I'm reading several at the moment. And is the purpose of this tape to protect the fuel rail from heat?
Protect from heat...the rail and the injectors.
$75. On our 1600 mile victory lap after rebuilding my Jeep the only code I got was injector 6...not a misfire. It was really hot...100 plus a couple of days and low speed bumpy driving.
Ordered this kit when I got home. Still had issues, but no regrets because I know it'll solve other issues down the road.
Two other things I fixed...the cat was plugged...so I replaced that with a butchered together set of stainless pipes... exhaust downpipe was also hitting the front driveshaft. Front O2 sensor died, replaced that.
Jeep is running much better now...but I'm getting what I would call a lean stumble.
Last problem is fuel pressure is 35-38 psi and I believe it should be 43. New regulator coming next Thursday and it's probably the last one we'll get from Custom.
I swore I put the new one into my Jeep on the rebuild...but seeing as how the back end was hit so hard it snapped the fuel pump plastic assembly in half...well...makes sense something broke or isn't working right.
Need to tig an aluminum pump frame, put in a Walbro with an external fuel filter, regulator and return line.
-Mac
