What are the two best days of one's life with a boat?so I can make my outdrive pretty again before I sell my boat for a motorhome!
The day one buys it and the day one sells it.
When I needed color matched paint for my red LJ I used these guys. They have aerosol cans as well as paint in a bottle. The color was spot on and I would recommend these guys.
http://www.automotivetouchup.com/index.htm
Ok. I checked amazon, found the alodine, but not the prep. Will need to figure this out by spring, so I can make my outdrive pretty again before I sell my boat for a motorhome!
Not true in my case. I'll be sad to see it go, but we just don't use it anymore, since my wife has a disease that essentially makes her allergic to the sun. Its not so bad that she has to completely cover up, but being on the boat, with all the reflected UV from the water, is tough on her.What are the two best days of one's life with a boat?
Any brands you’d recommend? Is that rustoleum by best bet?it is sold on amazon..did not see any precautions about not shipping to CA
https://www.amazon.com/dp/B000N8LR24/?tag=wranglerorg-20
also rustoleum
7400 System Zinc Chromate Primers
is sold all over San Fran according to rustoleum site.
I cannot help you on reco, I was just researching the fact that it could be had in Commiefornia. I am sure there are plenty of opinions on what has worked for others.Any brands you’d recommend? Is that rustoleum by best bet?
This is what we do to all aluminum parts on aircraft.
sand and clean with alcohol
alodine
spray Cromate primer
paint with topcoat.
how to clear lungs of spray paint
keep in mind this is aircraft and held to the highest standards. You can get away with just standing with 220 grit clean then cromate prime.
Going to try doing the aluminum part of my rockers my self, as I plan on getting the whole Jeep repainted in a year or two and then I’ll have them professionally done.
For my black (PX8?) is mopar paint the way to go or any of the other brands recommended? I saw there was all sorts on amazon and of course duplicolor.
Do dealers sell the mopar spray paint?
