https://www.motortrend.com/plus/detail/cams-how-small-is-too-small/5150927/
Engine Masters did a test of 3 different small cams. I don't know that the SBC and a 4.0 would react the same, but the dyno showed too small of cam 200 [email protected]" did not outperform the medium 212 [email protected] cam. The smaller cam had only a few pounds of torque more than the medium, but the small cam fell off at around 3400 rpm.
I have a Comp 163-201-5, I might have gone up to the next larger cam had I saw the video before my combo was set.
Advertised Intake Duration:250
Advertised Exhaust Duration:258
Intake Duration at .050 Inch Lift:205
Exhaust Duration at .050 Inch Lift:213
Intake Valve Lift:0.450
Exhaust Valve Lift:0.450
Lobe Separation:113
Displacement and head flow is everything with cam size. Put a large small block cam in a big block and its a small torque cam. I have a larger cam than that in my stroker and it is a very conservative low rpm cam
