hello my fellow jeep peeps. so i decided to buy this 4 inch lift for my 2004 wrangler. i have alot of mechanical experience but not on 4x4s or wranglers for that matter. i thought this would be a quick and easy job but was i wrong. so far i have shattered one torx, and have went through 4 cans of pb blaster and had to cut the sway bar links and the shocks off. anyways my problem are these front lower control arms. the rear bolt came out fine but the front i could only get loose from the nut side. is there a special trick to getting these out or could it just be stuck? thanks in advance i appreciate any and all comments
