The shock travel for that one is -10”. https://www.gorancho.com/products/s...er/rancho-rs5000x-shock-absorber-rs55255.htmlThe only number I can find that means anything is the RS55255 that is just the generic model # for the RS5000X. Mine should be the ones for a 4” lift.
Indeed. If the lift is 4” and the control arm is set right, then I’m not understanding why there would be so much shock exposed. I don’t even have a winch.we really need someone to chime in here that knows more than what i can offer.
the shock seems to be offset but i'm still not sure if that could be responsible for what you describe unless the offset is so far it's messing with the way the compression balances or if your topping out the shock and feeling that.
This is what mine looked like BEFORE I had the CA’s installed. I can’t figure out why the change would have happened. CA’s don’t change the height - only axle orientation. I installed 3 adjustable front CA’s last weekend, and then had the 4th put on by a shop because I couldn’t get the last one lined up to get the bolt in.... The only other work I’ve had done besides the CA’s is new ball joints.
What is the length of your control arms now? Measure it bolt to bolt.This is what mine looked like BEFORE I had the CA’s installed. I can’t figure out why the change would have happened. CA’s don’t change the height - only axle orientation. I installed 3 adjustable front CA’s last weekend, and then had the 4th put on by a shop because I couldn’t get the last one lined up to get the bolt in.... The only other work I’ve had done besides the CA’s is new ball joints.
I’m at a loss as to why the ride height has changed after all of this.
ok lets think......... the shock is on the backside of the axle, if the pinions to low the shock side of the axle would also be lower and it'd extend to reach..................is this possible?
What arms did you install? Was the Jeep on the ground before the arm bolts were tightened?
It was on the ground when I installed the 2 front/lowers and 1 driver side/upper. Can’t say for sure about when the mechanic put on the passenger side upper.I was having trouble getting the axle pulled back to align in the upper hole (towards the back of the jeep) so I had a mechanic do that one. Plus I had a rounded out bolt.was the jeep plated on the ground when the CA's bolts got tightened?
You need to loosen all the mounting bolts, bounce on the Jeep a couple times and then tighten them back up. I bet the bushings are in a bind.Core 4x4 T1 adjustables.
