2006 LJ rubicon
I'm installing 4" lift springs (actually 4.5") and see I have a choice of front control arms on the market.
case 1 - I'm tentatively looking at fixed length lowers (it states they are a length for a 4" lift) and upper adjustable arms for caster correction. I assume the fixed length will center the bumpstop adequately on the pad. I like the 'dog leg' style for increased clearance
case 2 - I see I also have the choice of going with adjustable lowers (I assume to center the bumpstop as well as play with caster) and either fixed or adjustable uppers.
Is there any reason to go with either case 1 or case 2?
ps - I have a Nth Degree stinger on the back axle so don't need uppers, and I do the pinion angle adjusting differently. Looking at getting the 'dog leg' style for a 4" lift on the back axle as well
If I go with case 1, before I buy I would find out the length of the fixed lowers (front and back) and check if they are close to what I need to center the bumps
