I would guess that at that price, you won't sell 50 a year. Last NOS frame I found was 2500. Add to that, you're fighting an uphill battle trying to get acceptance of a plastic frame (no matter how highly engineered, people are going to hear plastic) and the ease of which steel can be modified...
Not only the DIY guy, but how many shops have experience bonding plastic? I know it's not a trivial thing to do. Special adhesives, cute time, UV, heat, applicators, etc. Lots to learn...I hope your thinking about liability.
You are correct, Plastic (ie Petro based Polymers do not play nicel (Creep, Reduced Stiffness abd Strength) in ETD (Elevated Temperature and Dry or Wet Environments) ... they also are Flammable unless retardants are added which add cost, weight and redue Stiffness and Strength. My design uses Geopolymer a cementitious quasi-ceramic as the matrix.
My design does not intend to compete with used or NOS Frames, it is an improvement with a manufactured Cost Point that is close to the NOS Price Point of equivalent mass and welded blank or hydroformed Ladder Frames (ie JK, Tacomas, Frontiers ...)
The Baseline Configuration will be the OEM specification ... all “Bolt-On” aftermarket modifications will fit the fully Assembled Frame. For those DIYers that need HDPT location flexibility ... the Frame Rails, XMBRs, all Bracketry fasteners and Adhesive can be provided in a Knock-Down (Flat-Pack) configuration. This permits longitudinal Bonding and Bolting position of the Brackets to be determined by the End-User. Lateral and Vertical position requirements are accommodated/specified in the Bespoke Composite Bracket. Additional Bracket location flexibility (moment limited) can be accommodated with Universal Composite Adapters which introduce loads into the Frame and provide a bolting interface to End User Steel machinings or weldments.
The Bond and Bolt requirement is to accomodate Build Variance (Surface Prep and Bondline) of the 1-Off Frames in a non-controlled shop ... factory assembled Frames will not require fasteners... I expect that repeatable, precision located HDPTs and Dimensionally verified frames will be desirable.
With respect to Liability... the frames will conform to current FMVSS and Global NCAP sections for crashworthiness ..initial LS-DYNA simulations correlated to Physical Frontal (all) Side and Pole Impacts...
Jeeps were exported globally ... the new frames will also be global...
I hope the above adressed the identified concerns ... of course I could have overlooked something ... but that is why I created this thread ...
