Daily Driver, Go Where I Want To Build
When I shake the engine I can make the clicks happen. Can't do it when I shake the body the same way.
From the driver's side, if I pull lightly on the valve cover the relays click!
Pretty sure I found it!
This harness that runs over the exhaust by the starter.
I poked it with a stick and got a couple clicks. I have moved the harness around enough so that the short isn't active right now. The Jeep is running in the kill position and I can rock it all I want.
So, the problem isn't truly fixed. But I am nearly certain that I know where it is.
Reactions: derekmac
Over another weekend, I pulled half of the main wiring harness out looking for the bad wire(s) somewhere between the transmission and firewall that cause a shut down but found nothing. I hope that the real problem was just a bad connection and that taking everything apart and putting it back together was enough to fix the issue.
-Writing this a year later, I never did find that actual cause. All I can figure is that when I unplugged the front half of the main wiring harness, I corrected a bad connection somewhere. Despite my best efforts, the engine has never cut out again. Problem solved?
Apr 22, 2017
My experiment in saddle blanket seat covers begins.
The old neoprene covers that came with the Jeep are getting a little worn and gross. I've never liked them since day one.
Bought a 5lb ABC fire extinguisher and used the Jerry Bransford under seat mounting system.
To answer your first question, yes the seat can slide all the way forward.
And I can still reach underneath to grab the winch remote. And I don't believe it will ever fall out while driving. It's a pretty snug fit in the mount.
Reactions: danof76 and JMT
May 30, 2017
And an update on the blanket seat covers... After some rain and a bit of hotter weather, I can easily say that heavy wool blankets are a million times better than neoprene. They aren't clammy or slippery. They dry quickly. They breath and don't feel anywhere near as hot. So far this a is a successful experiment.
Reactions: Equilibrium31
A while back, I mentioned that the soft door windows are too high for my homemade side mirrors. These are the new ones. Revision #5. Newly bent arms and a larger convex mirror. Everything sits a little bit higher and is visible through the soft windows.
Ran Saran Wrap and Eagle Rock near Colorado Springs on Sunday. Not a single sign of the electrical problem!
This is the section where I smashed my new tail pipe. :(
Then the radiator popped. It survived 123k miles and 14 years.
I need to drive to work for a few days before the replacement arrives. This was the typical failure where the top tank split. I clean and sand it as best I can. Then smear it with a thick layer of epoxy. I also mixed in some nylon fuzz from a ratchet strap to add some reinforcement.
This lasted a week before the new Mopar radiator and water pump arrived.
Reactions: derekmac
June 19, 2017
Since I am pulling apart the cooling system, I decide to conduct another experiment. Your immediate response will be to not do it, but hear me out.
I am going to replace the factory 195*F thermostat with the next hottest thermostat, a 205*.
I have daily driven this thing for the last 3+ years with Torque displaying my coolant temps. Since installing the cowl induction and now the hood vents, I have seen the normal temps decrease with each. Even today on a 90*+ day, the coolant is consistently between 193-205*. During highway driving, the temps are constantly bouncing off of the thermostat.
A related observation is that since the hood vents went in, I feel like my mileage isn't were it ought to be. I have wondered if the engine is too cold. Normal temps are closer to 210* with the typical reasoning being that it improves efficiency. My engine never experiences normal temps.
My prediction is that because the t-stat controls the bottom end of the engine temp range, my engine temps will stay pretty consistently at 204-05* and rarely get hotter than that. Maybe I will see improved (restored) mileage.
This will be a hot week where I can continue to watch the engine temps.
Data. 195* thermostat
102°F on the rear view mirror.
The highest temp I saw from the PCM was 206.6°F while sitting at a stop light. Inching through traffic was 204-5°. Normal driving brought it as low as 197°F.
-The next day-
84°F on the rear view mirror this morning.
Nearly identical results as yesterday in the hotter weather.
-The next day-
The radiator and pump are installed.
Temp data on the first drive home with a 205* t-stat...
77* on the rear view
highest temp was 210* at a stoplight. 205-6* while driving. Lowest I saw was 197*.
It won't get hot here for another week, it appears as though the overall temps went up a couple degrees.
-Writing this today-
After 9 months with the 205* thermostat, I can say that the average engine temps did increase a few degrees. Normal temps are in the mid-200's and still occasionally dip into the 190's. I don't know what I accomplished. Except that the engine does not overheat in the summer and the heater in the winter is better than i recall in previous years. :)
Reactions: derekmac
This is the point in time when Photobucket ruined the internet and my original build threads died. What follows is new content!
