3.69 here and I’ve never rubbed my antirock with my 35 x 12.5’s.3.5 on 12.5 wide
Interesting. I’m not sure why mine does then.3.69 here and I’ve never rubbed my antirock with my 35 x 12.5’s.
A design that stood the test of time, no reason to change it.30 years ago, I used this exact same tire groover when my dad wanted to open up a set of Mickey Thompson tires he wasn't happy with.
This thing looks like a 1950's era sci-fi ray gun. I wonder when it was first designed.
Both eventually. The ramps leading up to the center tread faces are going away. And those lugs are going to be made smaller as well as siped. I'll draw it out soon.are you gonna sipe them or cut grooves to make the large center pads into smaller 1's?
I was able to dial it almost all the way out by putting it “in the corner” as you said, but still needed a washer to keep it from grabbing at one side hard bump steering lock.Both sides? If you adjust your link length you can change the arms position relative to the tire and position it in the "corner" of the tire.
Slow speed event, all meaningful damage avoided by paying attention to the tire sound on the bar and correcting or adding a thin washer.When it would happen, is this a slow or a high speed event? Would any meaningful damage occur?
I saw almost the same, shortening the links is a good idea. If you were to shorten them, would it still be enough to keep them not straight?Full stuff, almost full lock. The tire is pushing the AR into the grill.
I think I will shorten the AR links a bit to bring the heim lower relative to the tire, which would also move the arm down and away from the grill.
This is the current full droop. Good amount of room left before the links are pulled straight.
Grease zerks on your heims? Never seen that.
