2nd and 3rd ended up in the scrap bin (I could not create a clocking ramp i was happy with).........then struts changed my game b4 i used that stuff i showed + a clocking ring.
Artec makes a metal clocking ring 99$. several MFG's make it in rubber/poly but have to wade through sizing them.
the JK is slightly different that's why it not a perfect match, i wasn't making parts for a TJ axle.......... just an axle. (and now i'm embarrassed i even showed um).
i was gonna use some small axle shock brackets/tabs hung above the LCA and off the the side some, this would allow some control over the travel split of my shocks. and not get into/limit my CA or be right up tight on the spring.
the channel was long enough to come up to the TB bracket and support it, and in that position would leave the shock an open window to reach past. or i could lop it all off and go dead middle and rebuild what i needed.
i used UHMW for the bump block, it's light and dense. never gonna rot or deteriorate, flat to hold additional bump. borrowed the idea from Dynatrac. a steel cup could be added easily.
not trying to deter you , try it and see if you like it. it just didn't work out for me.
but i do have the caps, your welcome to those as well if they'll help. but they are trimmed real shallow.
and this is why i posed the question is it a clocking thing or a ramp thing. i think it's a ramp the clocking just positions it.
