I didn't even know you left the blocks there. I love the idea of the cribbing tower for a jack.
I didn't notice it until the next tire fell off the next day. Hopefully someone else is appreciating my old blocks as much as I did!I didn't even know you left the blocks there. I love the idea of the cribbing tower for a jack.
I'm sure they are! We really needed them based on how many busted beads with which we dealt.I didn't notice it until the next tire fell off the next day. Hopefully someone else is appreciating my old blocks as much as I did!
I know you think you're a scientist and all, but most "normal" people would simply call those 4x4's....a pair of 3.5 x 3.5 x 12" wood blocks
I was going for some kind of efficiency to show that my new blocks are both smaller and larger than the old blocks were without getting into nominal and rough cut lumber.I know you think you're a scientist and all, but most "normal" people would simply call those 4x4's....
Surface area is a fun ambiguous way to describe things, you could really confuse the masses.I was going for some kind of efficiency to show that my new blocks are both smaller and larger than the old blocks were without getting into nominal and rough cut lumber.
You mean like the surface area of the geometry correction bracket thread?Surface area is a fun ambiguous way to describe things, you could really confuse the masses.
That one or the one I was booted from.You mean like the surface area of the geometry correction bracket thread?
Surface area is not ambiguous at all. It's very defined. The product of length and width.Surface area is a fun ambiguous way to describe things, you could really confuse the masses.
Ohhh... Now your talking. Making people do some division!How's this? I went from 2.041 board feet of blocking to 5.833 board feet of blocking.
If you quote in square feet it absolutely is. There’s no way to reverse what size block was used with only that unit. “I chalked my wheels with 4 square feet of wood”, now tell me if it did anything!Surface area is not ambiguous at all. It's very defined. The product of length and width.
<pulls out a sheet of veneer>If you quote in square feet it absolutely is. There’s no way to reverse what size block was used with only that unit. “I chalked my wheels with 4 square feet of wood”, now tell me if it did anything!
Did you chalk them, or chock them? Inquiring minds want to know!If you quote in square feet it absolutely is. There’s no way to reverse what size block was used with only that unit. “I chalked my wheels with 4 square feet of wood”, now tell me if it did anything!
And now it is very clear why the geometry correction bracket thread went to complete shit...
It went to complete shit due to a very simple thing. If you employ the following statement PRN, with authority, and with a high level of frequency, the point gets made and they will figure it out or not but at least you don't have to type out lengthy explanations that are not going to change anyone's mind about anything.And now it is very clear why the geometry correction bracket thread went to complete shit...
It looked wrong typing it out.Did you chalk them, or chock them? Inquiring minds want to know!
