There is a lot to process here...Visuals of our discussion. For the next ones, I would just plug weld the back of both edges since it worked out to be more than plenty to attach the rub rail.
View attachment 326222View attachment 326223View attachment 326224
Yep, more than a bit considering we started with a set of GR mini boatsides for a TJ Unlimited, cut the stupid step off and went from there. These are high abuse, high clearance sliders with a rub rail to keep rocks out of the door opening. I like the aluminum, I just don't like the look. These will look much better when they are all painted in. We almost always cap the fronts to keep shit from getting kicked in on top of the bottom of the rail by the front tires. Plus it adds some strength to an unsupported area.There is a lot to process here...
Damn that is CLEANVisuals of our discussion. For the next ones, I would just plug weld the back of both edges since it worked out to be more than plenty to attach the rub rail.
I've seen a few snapshots of this and have been planning to go this way with mine. Other than aesthetics, what are the reasons to prefer steel or aluminum for this application?Visuals of our discussion. For the next ones, I would just plug weld the back of both edges since it worked out to be more than plenty to attach the rub rail.
Something else I need to do to my JCR sliders to "fix" them. They collect a ton of shit on the bottom of the rails.We almost always cap the fronts to keep shit from getting kicked in on top of the bottom of the rail by the front tires. Plus it adds some strength to an unsupported area.
Not sure there is a valid reason other than aesthetics. I don't mind the aluminum, I just wanted something that looked like it belonged there.I've seen a few snapshots of this and have been planning to go this way with mine. Other than aesthetics, what are the reasons to prefer steel or aluminum for this application?
I forgot the best part. We split a piece of 2 x 2 x 3/16" wall square tube with the Milwaukee metal cutting circular saw using the short side of the base plate as the guide against a piece clamped to the side of the tubing.Damn that is CLEAN
So... The rub rail. The screws go through that into the tub? When I first looked at it, I though it would be removable, similar to Savvy, but then I noticed the welds.Yep, more than a bit considering we started with a set of GR mini boatsides for a TJ Unlimited, cut the stupid step off and went from there. These are high abuse, high clearance sliders with a rub rail to keep rocks out of the door opening. I like the aluminum, I just don't like the look. These will look much better when they are all painted in. We almost always cap the fronts to keep shit from getting kicked in on top of the bottom of the rail by the front tires. Plus it adds some strength to an unsupported area.
The circled screws go through the rail, through the original holes in the boat side and into nutserts set in the body sheet metal. The others are through bolts.So... The rub rail. The screws go through that into the tub? When I first looked at it, I though it would be removable, similar to Savvy, but then I noticed the welds.
You also said its tube correct? What is backing up those screws?
Are you referring to the stretched section?One question - what is that overhang going past the rear wheelwell opening?
Yes, this bit.
It looks like he is doing a stretch on this rig (notice the YJ fuel filler) - so it's probably also getting his under-seat gas tank too. It just is missing the armor blanks cut to cover up the original wheel well opening.Yes.
