I have posted about this in a few other posts but hoping to get more responses here. I have been chasing a cylinder misfires for a few months now. All this appeared to start after I changed out a bad crankshaft position sensor. Since Mopar units are no longer an option, I installed an NTK sensor and the Jeep started and ran great.
Fast forward a few weeks while driving on the interstate over 70 mph at approximately 3100 rpm and I start getting a flashing check engine light. There are no noticeable changes to how the engine runs at high or low RPMs. It continues to run very smoothly and idles fine. I check the codes and get p0304 and p0306.
From here I changed out the spark plugs for a new set of NGK (old ones still looked fine but figured a refresh wouldn't hurt). Jeep still runs fine after this with no noticeable change but the issue still continued. Did not check the codes since I planned to take it to a local shop.
Took it to a shop to get diagnosed and shop said I need a new crank position sensor (which I just changed) and a coil rail. I asked them how they figured this and they just said the "codes told them". Regardless, because I could still buy a Mopar coil rail, I figured it would not hurt to freshen things up with a new one so I had one installed at a second shop. Jeep continues to run fine with no noticeable change but the issue persists. This time, I see codes p0300, p0406, p0306.
This time, I took it to the dealer hoping the dealer has a fancy scan tool that can view live data. Dealer performs a fuel induction cleaning service to verify that carbon buildup is not the issue with no noticeable change. Just to confirm it was not the NTK sensor at fault, I bought a NAPA Echelin sensor and asked the dealer to install. No noticeable change. Finally, the dealer runs a compression tests with the following results:
Cylinder 1: 175 psi
Cylinder 2: 175 psi
Cylinder 3: 150 psi
Cylinder 4: 160 psi
Cylinder 5: 180 psi
Cylinder 6: 160 psi
Seeing this, they performed a leakdown test and reported that cylinder 3 has a 45% leakdown through the exhaust valve!!! The dealer now suspects a faulty valve and/or cracked head for cylinder 3.
A few notes about my 2001 which most likely has the 0331 head. Through this entire saga, my Jeep has continued to run fine. If anything, performance has improved especially after installing the new plugs but in the 20+ years I have owned it, I would say it runs the same as the first day I drove it off the lot. This Jeep has also been garaged for the past 10 years and rarely sees any extended use and certainly no hard use. I did recently drive it for 8 hours under 3100 rpm with no check engine light and no issues so temperature does not seem to be a factor here. It is only above 3100 that the flashing CEL occurs.
A buddy of mine that builds a lot of Jeeps is calling BS on this and insists it is an electrical issue or issue with the cam crank sync. He says if it was cylinder 3 like the dealer indicates, the code should confirm this and so far I have not seen it. He also says that at 3100 rpm, the engine does not even have a chance to leakdown.
I am prepared to buy a new head with all new valves and valve train but hoping for some additional inputs here. Could this be the dreaded 0331 head cracking? I've only put about 60k miles on this over the past 10 years of very light weekend driving so I have my doubts about this too.
The final code check after picking up the Jeep from the dealer: p0304 and p1389??? Now I am wondering if there a speed sensor at play here that could be causing this?
Thanks.
Cylinder 1: 175 psi
Cylinder 2: 175 psi
Cylinder 3: 150 psi
Cylinder 4: 160 psi
Cylinder 5: 180 psi
Cylinder 6: 160 psi
Thanks.
