I'm now at a point where a decision needs to be made on what do do about the rear. The Jeep is a 2004 LJ, with a stock LJ 3.73 disc brake rear. While I say the maximum tire size I see is 35, I do believe there could come a point where 37s might find there way onto the Jeep. While this is a remote possibility anytime soon, the fact that I'm thinking it tells me to plan accordingly.
With that remote possibility, I don't want to waste money. This leads me to the decision that needs to be made. The way I see it there are two paths to take:
- Option 1. Buy an Eaton E locker and install that along with 5.38 gears (The front has a Rubicon 44 that I just installed) in my current rear. Then, if I did decide to go 37s in the future, I'd have to sell it and upgrade later.
- Option 2. Purchase a complete Currie HP Dana 60 now, with E-Locker and 5.38s
The cost difference between the two is significant. With Option 1, I'm looking at roughly $2000 - $2200, which includes someone else doing the re-gear for me. With Option 2, I'm looking at $5800, so that's a $3600 delta. For that difference, I get a much stronger, even with the semi-float design, rear that could hold up to a 37" tire and I don't sacrifice ground clearance.
The only things making me hesitate are the stock 60.5 width and the fact that I'd also need to factor in a rear AntiRock to get the most travel at full droop. The stock 60.5" width is really the big factor making me pause. Common sense says if I'm going to go to the trouble of buying and installing a Dana 60, it should be a minimum of 63.5' width. Thoughts?
