Slightly unrelated, but you probably have enough experience with the different types of bearings to answer....have you noticed either model (early or late YJ/TJ) lasting more or less time than the other? Is the later version an "upgrade" to your inowledge, or just different? Of course assuming both are installed with the stub nut torqued properly and running the same tire size and wheel BS. I'm curious if there are any advantages of one over the other at this point that you've noticed.
Not really. I prefer the later ones whenever possible due to the better rotor registration pilot and slightly longer studs.
