Tomorrow we shall know
Did you check the outer edge of the pads to see if they are close to flush with the edge of the rotor?
I have not.
Assuming that is where the two different size calipers come in? I will double check tomorrow.
I've set up and built a ton of big brake kits from scratch. When I see a gap as big as the one between the end of the saddle and the edge of the rotor, that typically points to the pads hanging way over the edge of the rotor. Hopefully that isn't the case but if it is, something will have to change. Either a larger diameter rotor or a different caliper. That caliper can't move inward towards the hat much more unless the pic is messing up the angles and there is more room than it looks like.
Summary of this whole setup:
This works super well. Braking performance is way better. For a street only Jeep (like mine, hopefully not forever….), this is probably a great option. I would however feel better with new knuckles in the BMB/Vanco kit but at this time for the 1,000 miles a year I use it I just wasn’t ready to buy the kit.
I’m not nervous to run this at all but at some point I see buying the kit especially if I start using it at all.
That seems like a very DIY project. How do you like it so far?
To be honest I have not driven it much and the Jeep is parked for winter. It certainly is an improvement though and isn't ridiculously more expensive than buying new stock pads, rotors, calipers (except that you have to do ball joints, etc.).
This, this is what makes this forum and @mrblaine one hell of a guyThat said, if you head down that road, post up, I've done lots of custom brakes and brake conversions and will be more than pleased to provide you with all the technical support you need to pull it off. It is always good to see folks figure stuff out.
