@GregBelleville I agree with Jerry about the front lunchbox locker. Also, while it may be rare, I broke a front axle stub in a stock Dana 30 running 33’s with a lunchbox locker.
Ok #1 replace that shitty-filtering K&N with a good air filter like from AC-Delco, Purolator, etc. K&N air filters are absolutely the WORST at actually filtering out the harmful stuff like silica, dust, dirt, etc. You will not lose ANY power, none whatsoever, by replacing the K&N. The TJ's factory air intake with a conventional paper element air filter like from AC-Delco is not restrictive (!) will easily flow more air than the engine can consume at wide open throttle and redline rpms. The below is from an ISO 5011 certified lab test of various air filters. Notice the lab's last sentence below, bolded for emphasis.
But let's get to what is likely the reason for your lack of power, let's take a look at your axle ratio. If your TJ has the dreaded 3.07 ratio that's the reason. With the wrong axle ratio for the size tires being run your engine rpms will be too low and the engine won't be able to generate enough power for the size tires being run.
There's a tab bolted to your differential at its 9 o'clock position. The below tag indicates the gears inside the axle have a 3.73 ratio. What does your tag say? 3.07? 3.73? If it's a 3.07 you would pick up a significant boost in power by regearing to a lower axle ratio like 3.73 or 4.10. Regearing will raise the engine rpms up enough to produce enough power for your 31" tires.
Both diffs get a tag from the factory. But they're often left off when changing the lube or other work is done.That tag is supposed to be on the rear diff? It is on the front of mine.
Your profile doesn't tell us about your Jeep. Year, transmission?Also, mine says 3.73 and the RPMs are about 2300-2400 at 60mph on the freeway with 33" tires with the 32RH. It feels underpowered. I'm thinking about going with a re-gear to 4.10 or more. How much do these usually cost?
You'll more likely want 4.56 for a manual tranny, or even lower gearing for an automatic, depending on which one you have.
I've got a 3 speed 32RH.
You're struggling up Donner Pass because you're only running 4.56 with 35's which is on the verge of lugging for that size tire. Really, 4.88 would have been a much better choice. I ran 35's and 4.88 with the AX-15 which is not geared quite as low as your 6-speed is and it did fine regularly going up to my local mountains. If you live at a higher altitude 5.13 would be a great choice too. Many would recommend 5.13 for your transmission and 35's even if you don't live at a higher altitude.
Wait, so papa Jerry, i’ve been doing some serious thinking, would I benefit from re gearing my 33” for 4.56? i’m about to pull the trigger on a complete rebuild for the front and rear axle, i live in Canada and almost always have to use the Highway to get anywhere so the speed limit is 60mph, would it give me any downsides, i’m also planning on sending the jeep to Madagascar for a big trip, so please lend me your expert opinion
I think Jerry got fed up and left the site. One thing you can do is compare your Jeep as it came stock with your proposed tire size and gear ratio to see how it compares.Wait, so papa Jerry, i’ve been doing some serious thinking, would I benefit from re gearing my 33” for 4.56? i’m about to pull the trigger on a complete rebuild for the front and rear axle, i live in Canada and almost always have to use the Highway to get anywhere so the speed limit is 60mph, would it give me any downsides, i’m also planning on sending the jeep to Madagascar for a big trip, so please lend me your expert opinion
Jerry was misguided on gearing. You want 4.88.
4.88 with 33s and a 32rh, I think this is the first I've seen those gears recommended with that trans and tire size, which is what I've got as well.
What would rpms at 70 mph be, seems like they'd be way too high with 4.88s.
IKrea has a nv3550. 488 for 33s is correct.
That's what I thought, 3.07 is just a terrible ratio. Jeep made it a standard ratio thinking it would help the mpg rating but it has to be driven so much more aggressively that the 3.07 doesn't help the mpg in the least. I'd regear it to 4.10 which is the ratio the Rubicon came with with the manual transmission for its 31" tires. It'll be a great performing Jeep after regearing the axles to 4.10. Highway rpms will be ideal.
4.88? okay so with 4.88 would i be able to run 35s
Are we anti jerry wth happened
