Hi everyone. I just got my Jeep back from the shop. They installed a 2.5 inch lift with all 8 adjustable control arms. I wanted to know if the alignment looks okay? I wish the caster angles were a little closer but was wondering if it will be fine.
They numbers look good. Next time you can check your own alignment. It's very easy to do.
I wish someone would do a thread about a do it yourself alignment.
Keep in mind, the red and green are for factory specs.
Once lifted, those may not apply.
Lift height doesn't really affect it but tire size affects how much caster angle is required. The bigger the tire the less caster angle that is required.Keep in mind, the red and green are for factory specs.
The camber angle could be caused by either a bad ball joint or a bent axle housing. It can usually be adjusted back into spec with adjustable ball joints.Does anyone have an idea why the camber on the left front is off? I’m not too worried because it’s a slight amount but it would be nice to fix it eventually.
Probably but @mrblaine is an expert on them.My ball joints and U joints are pretty old so next summer when I get the brakes done that will be when I get all of that fixed. I assume it’s worth buying adjustable ball joints when the time comes?
As you rotate the joint, wouldn't anything other than max (or min) camber, also affect caster?
They look fine. The left and right caster angles will always be a little different from each other, that's how they're designed. The right side caster angle is a little less so it will tend to pull the vehicle away from oncoming traffic if the driver becomes incapacitated.
Actually Jerry most vehicles you want less caster in the left side to compensate for the crown in the road so the vehicle drive straight down the road.
Until you get on a freeway that is 5 lanes wide of flat concrete, or the crown in the road surface is more or less than the cross caster can handle. Or you get on the 247 from Boone road. Not sure what they did out there but every trip back from the lake bed my truck pulls hard to one side right after the intersection. Catches me by surprise until I remember it always does it in that area.
