Does anyone have a photo of these wheels on their TJ?
jacksonreese96
Abernathy, Tx
I know the wheel question is often asked. So I’ll ask it again, mainly because I haven’t found pictures of these wheels on a TJ. A friend has them up for grabs but can decide. So if you’re running these post a pic!
Here’s what I’m looking at and here’s my Jeep now.
You would need adapters for the different bolt pattern of the late model wheels. Not to mention those tires are 33’s so you would need at least 3 to 4” of lift
Reactions: L J
Well I don’t know what the question is-
This.
Plus, they're 18". You should really only consider 18" wheels if you need to go to a 37" or larger. For 35" or less, you shouldn't be going larger than 15" or 17". Even then, I would only do 17" for 35's. 33's should be on a 15" wheel.
I wouldn't consider using adapters unless there was a good reason. Wanting to use JK wheels is not a good reason. I'm using TJ to JK adapters in the front because I'm running 37's and they don't make any decent wheels that can run a 37" with a TJ bolt pattern. In the rear I have an aftermarket axle with JK bolt pattern, do don't need the adapters in the rear.
Reactions: L J and GPK03X
