Door switch
Brian Alcorn
Ok so I pulled the dash for the heater core and in the process I destroyed the passenger door switch .. and not only the replaceable button part . It destroyed the rest of it, like it's just the 2 wires hanging ... is this part obtainable or is this a salvage item..
Thank in advance
Reactions: JMT
Thank in advance
A few suggestions...
Pretty sure I still have the two stock door pins someplace in my parts shed. You're welcome to one or both if it will help. That would be the cheap route.
I used these small pin switches when I did the lighting in the tailgate. Simple and effective, though not stock by any stretch.
I removed the front door pins in favor of the Mercedes Interior Light switch which defeats the interior lights when you pull the door pin out. Easy to wire in but it looks like the price has skyrocketed. I paid $8 each when I did this mod a few years back. And you need to source a new thumb screw to install them, which I 3D printed. I'm sure I bought spares of both the door switch and the thumb screws.
Reactions: SkylinesSuck
Thank in advance
https://www.oreillyauto.com/detail/...17926/automotive-suv-2004-jeep-wrangler?pos=0
https://www.amazon.com/QSKCBXVL-Switch-Grand-Cherokee-Wrangler/dp/B0DFCGCTG6?tag=wranglerorg-20
Reactions: mjonesjr84
Reactions: Tom Andersen
Thanks all for the replies .. I know there's a tj in Madison so should be simple
Had a brain fart and checked my old dash harness but alas it must be part of the body harness as it's a door switch not a dash switch
Anybody have a clue if this fits.. guess if it's in stock I could find out.. says it fits
Thank in advance
Are you talking about the switch between the door jamb that turns the interior lights on and off? And what year is your TJ? I can't imagine that this switch is the same from 97-06.
Yes .. sorry so long on the reply
Reactions: LONGJP2
