If they are Beadlocks just do them yourself?
I thought about it but haven’t started the research for it. Assuming I would need some kind of tire mounter to start with..
Tons of videos on how to install tires on beadlocks.
https://www.google.com/search?sxsrf...QIHbFMDsYQ0pQJegQICxAB&biw=1920&bih=969&dpr=1
Put the tire onto the rim.
Tap the bead around the lip of the beadlock.
Put in all your bolts
Tighten them down and using a torgure wrench make sure they are torqued to the proper specs.
He didn’t buy traditional beadlocks, his mount like a normal tire and wheel.
Ya, only got a no from discounttire. He didn’t know what it was and I didn’t feel like debating it with him. I took it there first as I saw another forum with a discounttire rep saying those could be mounted at the stores. It really isn’t that different than mounting to regular wheels, just needs the bolts to be tightened down before putting the appropriate psi and balancing.
Got them in this past weekend. Just place an order for MT Baja Boss MT’s. Should be ready for pick up tomorrow.
I took the wheels to discount tire to see if they can install, they said no, since he didn’t know how and they are “beadlocks.” It really isn’t hard and the wheels came with a paper that gives you a step by step process. So, I’m going to be on the hunt for someone to mount the tires to them.
A Discount Tire corporate rep told me they have a corporate-wide policy against having anything to do with mounting tires onto beadlock wheels. Easy or not.Ya, only got a no from discounttire. He didn’t know what it was and I didn’t feel like debating it with him. I took it there first as I saw another forum with a discounttire rep saying those could be mounted at the stores. It really isn’t that different than mounting to regular wheels, just needs the bolts to be tightened down before putting the appropriate psi and balancing.
Okay, I'll bite, how does that little paper say to seat the retained bead with all the air leaks it will have with the bolts out far enough to clear the tire bead?It really isn’t hard and the wheels came with a paper that gives you a step by step process.
Looks like it, assuming their paper instructions match their video instructions.Okay, I'll bite, how does that little paper say to seat the retained bead with all the air leaks it will have with the bolts out far enough to clear the tire bead?
If nothing else works take them to 4WP Wholesalers, they sell that wheel and they say they install everything they sell.
Do they say they will also install something they sell if you didn't buy it from them?
I did think of another way to do this. Get some short bolts that seal up the holes but do not go into the inner part of the rim. Install them and just snug them down far enough to not let air out. Run them down to the tire store, get them mounted and balanced. If they say anything, tell them they are fake bead locks just like the other 10,000 they mounted and balanced last year. Get them home, pull the valve core, replace the bolts and you're golden.
This is what they came with, but that video shows a more expedited/“easier” process
