Engine Masters did a video on cams being too small. They dynoed 3 cams with 250, 260 and 270 advertised duration. The 250 and 260 had nearly the same tq down low, but the 260 started to pull away as the rpm went up. Their assessment was that the smallest cam did not make more tq because the valve did not stay open long enough. The 270 gave up bottom end and predictably made more HP. I don't have a subscription any more to watch it so if someone has HULU feel free to correct me.
The analogy russ pottenger gave me when picking a stroker cam was small vs big block engines. The big block will need a larger cam to not fall on its face at higher rims.
I chose the smaller of the two cams he suggested and wish I'd gone larger. The added cubes and high compression would have really liked a modified 235 cam vs the 231 I used.jezza's dyno results with the 231 show it is more for a 4.0l
