Build for the tire size you plan to run. You won't get near as much tire under a TJ as you can on a JK with the same size lift.
Yes, thanks for that info. I came to that realization really fast searching around on this forum. Based on what I’ve read so far I don’t plan on exceeding 33” on it. I had a 87 YJ for about 9 years and only had 30” of 31” on it, with a suspension and BL on it (can’t remember everything been too long). It went and did anything I wanted to do, including three runs on the Rubicon. So I suspect 33” will be fine for me, especially if I end up doing a TT someday. Even stock this LJ is a lot more capable then my YJ was.
