possibly..
I did turn on the defrost Friday night driving home from a softball game..
Heat and defrost still work, or it did last I used it prior to Friday night (6mo ago maybe) The AC doesn’t work because the previous owner had an audio fuse (that ran between an amp In the back and the battery) burn a hole in a refrigerant line (I’m surprised it didn’t catch on fire TBH) and it was going to be expensive to fix, so I never did.
FWIW, the burnt wire/fuse was one of the first things I replaced 3 years ago when I got the Jeep. But was unaware it had burned a hole in the line until I went to get the AC fixed and the mechanic showed me. I immediately knew it was from the fuse burning.![]()
What color is your coolant in the rad.
