Question for all you gurus out there. I have 2 TJs. One is an 01 and the other is a 98. The 01 is a rust bucket but complete so I’m swapping everything over to the 98. The issue I’m running in to is the motor mount situation. Other then the blocks being different and how the engine mounts mount to the block, does anyone know the actual differences that make it not able to just bolt in an 01 engine into a 98 chassis? Looking for ideas how to make this work. Don’t mind fabbing custom engine mounts if I have to.
