We fired up the 97 to start going through everything in preparation for getting it to paint. We were filling the radiator and it did the big coolant burp which is a pretty good indication that there isn't a bleed hole in the thermostat flange. I'm not gonna play that game so we pulled it and decided to do a water flush to switch over to the Mopar 5 year coolant. We found some gelled coolant in the thermostat housing so we replaced that.
Anyway, we were running it a lot to circulate the coolant through the engine and I decided to check it with the DRB to see what it runs at idle on a 60 degree day with no thermostat. 130 degrees, that's it and it would not go any higher.
I was right about the thermostat. No bleed hole, not even a jiggler. Drilled a 1/8" hole in the flange of the Mopar version next to the jiggler and zero issues getting it bled. No burp, air bubbles right up into the funnel. Bring it to temp, circulate, pop the funnel off, cap on, no problems.
