The idea of this build is to have it ready for a trip some of my buddies are taking to Moab in late March.
To start - I have a 2000 Wrangler Sport with manual transmission. I purchased it pretty much stock - the only thing that the previous owners had managed to do to it is add wider fender flares and remove a bunch of stuff - leaving it pretty barren on the inside (rhino-lined and no center console... only one cup holder ).
My goal with this jeep was to have something simple and reliable - nothing too fancy like my JK that I had a year back. I really like the JK/JL 'rubicon take offs' that you can find on craigslist - especially in Denver - so I have bought a set of JK moab wheels and rubicon tires - all said I have 5 wheels with good meaty 265/75R17 BFGoodrich Mud Terrain T/A KM tires for under $400 so far! I'll continue to keep an eye on craigslist for 'cheap jeep' stuff but in the interim I have a list of things I'm going to do for a more trail ready Jeep.
Step 1 was completed tonight - a nice clean garage and finally got my Tig/Plasma/Stick outfit setup - it's been in storage for about 4 years since I moved out here to Colorado (it can be surprisingly tough to not only find a place with enough room and power to weld - but more so it's flat out HARD to find a place out here with the crazy real estate market!)
Rock on!
- Convert the rear Dana 35 into a 'Super35' with revolution 30 spline axles and an Eaton eLocker - rebuild entire axle (seals/bearings) and add 4.88 gears, lube locker and a diff guard and finished off with a nice coat of enamel paint
- Change front axle's gears to 4.88, rebuild it like the rear, weld on a beefed up passenger side upper control arm bushing mount and replaced driver's side as well, weld on skid/gussets to the lower control arm mount, lube locker and a solid iron diff cover and finish it off with a coat of enamel
- Some sort of control arm set - too many options right now and haven't narrowed it down!
- 3" springs
- 1.25" body lift
- 1" motor mount lift
- no SYE/CV for now - so marginally lowering the t-case... hopefully not much
- RS5000x struts all around
- Front and rear adjustable track bars - not sure which brand
- Crown HD steering kit
- Probably finish it off with some LED retrofits... I love LEDs haha.
Rock on!
